I decided to up-cycle the original mounts.
They got cut out of the frame, ground to a 90 degree for the mount surface, and then tapped on the end to fit the original bolts.
I nicked the wires while trimming the shaft down to 18mm in length, so good reason to extend them right from the hub now.
