Tire mounting
A project log for A Wheel
Another Satisfying Single Wheel Terrifying Hoverboard Conversion
masterofnullMasterOfNull 09/03/2022 at 17:090 Comments
Got the crud out of my hub, so tire mounting is happening. I lubed the bearings good as well because this is probably the last time this gets taken apart until the tire needs changing.
I can’t imagine that happening for a very long time.
