Got the crud out of my hub, so tire mounting is happening. I lubed the bearings good as well because this is probably the last time this gets taken apart until the tire needs changing.
I can’t imagine that happening for a very long time.
![](https://cdn.hackaday.io/images/4291941662225481716.jpg)
A project log for A Wheel
Another Satisfying Single Wheel Terrifying Hoverboard Conversion
