There are two cabs mounted on opposite truck arms. These cabs are where the drivers sit. The one detail left to add is the big red wheel that steers the crawler.
![](https://cdn.hackaday.io/images/9850731665157387154.jpeg)
From the side you can see an A/C window unit that cools the cab.
![](https://cdn.hackaday.io/images/7339341665157461839.jpeg)
On the underside I added wires. It's the little details that add to the model.
![](https://cdn.hackaday.io/images/9682861665157510139.jpeg)
![](https://cdn.hackaday.io/images/9256251665157770498.jpeg)
