The center structure consists of a whole lot of I-beams and posts. There are also walls containing windows and doors. Within these walls is a computer room that is walled off from the engines and pumps. I have glued in everything except the top two I-beam pieces. These will be glued in later when the interior parts, engines and pumps are installed. Once the top pieces are glued in, I can true up some of the misaligned posts. The entire structure is 3 dimensional except for where the truck arms will attach. At that point you can see sheets of styrene. I wanted to get a really good attachment point for these arms. Now that I think about it, if you mount the LUT and Saturn V on top of this model, all the weight is placed on top of the truck arms and goes straight through to the trucks.
![](https://cdn.hackaday.io/images/1870771665702679527.jpeg)
![](https://cdn.hackaday.io/images/8105101665702717175.jpeg)
