This is the new Digital Bird 3D print Digital Pan head or video Turntable perhaps the most versatile component in the Digital Bird camera motion control system. As a turntable it is capable of moving up to about 10KG in weight and is perfect for product videos especially when working in harmony with the Camera slider and Pan Tilt head. As with all parts of the system the head is programmed using either the Compact or PTZplus WIFI controllers.
The system is ESP32 based and uses a magnetic encoder behind the stepper allowing you to manually position where you want it to start and finish without the need for joystick or app control. Having camera shutter control makes it perfect for photogrammetry (3D scanning) since it offers programable shutter control. The head will also be a part of the up coming Digital Bird mini Jib.
