Here is the final schematic for the Weather Station V4.0. It has two sheets, the first sheet is related to the charger, power supply, and the ESP32 board. The second sheet is on the interfacing of the LoRa module with ESP32 and all the weather sensors.
Sheet-1:
Sheet-2:
