I used my Creality 3D printer and 1.75 mm white PLA filament to print the parts. I will recommend using ABS or PTEG filament instead of using PLA. I have used PLA just for the quick test as I don't have ABS or PTEG filament in my stock.
My print settings are:
Print Speed : 60 mm/s
Layer Height: 0.3mm
Fill Density: 25%
Extruder Temperature: 210 deg C
Bed Temp: 65 deg C
I have printed the files successfully but there are minor issues in the fitting of a few parts like M4 rods, and middle cover, and the top cover. I will adjust it soon.
I have also checked the solar panel fitting, it works as expected.
