Today I assembled the PCB board, but the USB port was not soldered due to the unavailability of stock. As the USB port is not soldered, not able to upload the program now, Place the order for the USB-C port, it will be delivered by this weekend, I will update the results then.
Placed the components using Solder Paste:
Assembled PCB:
Did you publish the software of the receiver ( I can't find it, I can find only a test program for the transmitter )?
