My version of this project uses a 12v diaphragm pump to pressurize the water. It's an on-demand pump, which means it automatically turns on when there is a demand (ball valve opens), and turns off when there is no demand (ball valve closes).
If a pressurized water source is available, the pump is not needed. Just hook the ball valve directly to the water source.
Scott Feldman
