Temperature monitoring inside beehive is very instructive.
This can help you decide when to install your hive extension, as illustrated above.
Measuring the humidity inside the hive extension can also be a tool to decide if the honey is dry enough.
A project log for Beehive Monitoring and Tracking
Add and monitor sensors in a beehive to follow bees life.
