Temperature monitoring inside beehive is very instructive.
![](https://cdn.hackaday.io/images/2906231665867609425.jpg)
This can help you decide when to install your hive extension, as illustrated above.
Measuring the humidity inside the hive extension can also be a tool to decide if the honey is dry enough.
A project log for Beehive Monitoring and Tracking
Add and monitor sensors in a beehive to follow bees life.
