The need is for the local residents to be able to tell from a distance if the bridge is flooded. It is the shortest route between locations in this mountain community, and, if the bridge is flooded (blocked) a rather long detour is required.
The intent is to build a reliable flood sensor so that residents can refer to a digital online map (probably Google) to tell if the bridge is flooded.
Additionally, since the sensor will be continually operating a historical record can be compiled and compared with weather patterns for potentially predicting flood conditions.
Being in a rural area, the cellular coverage is spotty at best so a LORA-based solution is being pursued.
And since LORA is low-power by design, and solar panels can be rigged for the sensor system, the intent is to have little or no maintenance required for power.
Charlie Lindahl
Marco Camilli
Edward
Amanda Leigh
Rasmus Ljungmann Pedersen
