Some years ago I stumbled over Telgram Bots
This is a simple chat bot that can be controlled via you Mobilephone.
On the other side a Microcontroller e.g. an ESP8266/Arduino/ESP32 receives this commands and can interact with you. This might be used for basic Smart home tasks. After I got my last GAS bill we talked in our House what we can do to change the cost of living. So we decided to check our heating system. While doing that we figured out that there is a waterpump conctantly pumping hot water in a circle. This water lines where not isolted and heated up the whole house and the walls in summertime.
This waterpump was pulling this water out of our central heating system water storage. While pumping this hot water in a circle in our house the water cools down.... Therefore it must be reheated once it is back in the heating system.
Why is this done:
This is done purly out of comfort. So whenever you open up the tap the water is immediately warm and you do not have to wait 30 sec
Sooo we decided to do something to cool our walls and reduce our gas bill.
An idea was born to operate this waterpump only when really needed. e.,g. for showering. And what is better than controlling this with a Telegram Bot with your mobile.
Ulrich
Ben Nitkin
MechaTweak
