serial pins
A project log for eepromgrammer
A more generic eeprom programmer using Arduinos.
alvaro-barcellosAlvaro Barcellos 09/02/2022 at 22:060 Comments
Top 8 pins
The top 8 pins pins-outs of zero-insertion-force (ZIF) socket, are reserved for I2C and SPI, : with follow setup.
SPII2CPIN
PINI2CSPI
/CSS01
40VCCVCC
SOS12
39WR/HOLD
/WPS23
38SCLMSCK
GNDGND4
37SDAMOSI
OBS.
pull-ups 4k7 resistors at (S1, S2, SDA, SCL, WR) and pull-down at S0.
I2C or SPI must be select for use, or go in tri-state.
Rich text editor
