I chopped enough choc mini switches to finish one hand.
I soldered short lengths of wire to each switch pin to make wiring easier after they are glued into the keywell and reduce the chances of melting the PLA by accident.
This is a 1x3 column for the middle finger which is why the top row space is blank.
