I chopped enough choc mini switches to finish one hand.
I soldered short lengths of wire to each switch pin to make wiring easier after they are glued into the keywell and reduce the chances of melting the PLA by accident.
![](https://cdn.hackaday.io/images/5743041662869791421.jpeg)
This is a 1x3 column for the middle finger which is why the top row space is blank.
