Based on the accumulated results from the survey, the Mindful Droid will be a visually informative and educating device to raise awareness and bring the reality of air pollution around school areas and commutes. It will not be invasive but a subtle constant reminder of the effects of emissions and actions to help reduce them. Psychologically, this would lead to taking positive actions and changing behaviours subconsciously with the information absorbed.
The Mindful Droid is set to be proactive and not reactive to air pollution and if the information is repeated enough the mind will subconsciously take it in.
Please see survey below and how it will influence the Mindful Droid.
![](https://cdn.hackaday.io/images/7504481666528620899.jpg)
![](https://cdn.hackaday.io/images/6128001666528602648.jpg)
![](https://cdn.hackaday.io/images/4255801666528594944.jpg)
![](https://cdn.hackaday.io/images/3376061666528585346.jpg)
