Another small example of what Ethersweep can be used for. The setup is fast and easy, and all programming can be done on one machine that uses a normal USB webcam and standard Ethernet to communicate with the motors. No specialized interfaces or hardware are needed except the Ethersweep controller.
This shows, how simple it is to connect a vision pipeline to the actual movement of actuators. Reaching the same with a PLC would take much more effort and money to achieve the same output.
Jan Neumann
