I'm currently looking at options for the physical control aspect of this build.
While my makeproaudio device is brilliant, it is reliant on a network connection in its current guise, which complicates the plan. My original thought was to run an ethernet cable directly between the lattepanda and the Pi in the MPA, but I also want to test out usb midi control too.
To that end I've ordered a few midi controllers to try out over the next week or two. Exciting!
