The DYNABRIX pieces will be optimized by injecting polyurethane foam around a semi-cured trash-aggregate shell. FreeCAD is proving to have a somewhat arduous learning curve. I've also been fitting electronics components into a found, neighborhood recycling bin that no one was using. It's "recycling the recycler," I guess...
Mink Stacktrane
