Soooo, I was supposed to send this yesterday but am holding back since I want to check the lens within a full model first!
As you can see, I designed a simple enclosure for testing the lens! This version will hold two 2.9 inch LCDs, the drivers for it, an IMU and Arduino! I might also add in a Raxda for some simple PCVR experience with 6DOF!
From this, I am going to make a test headset and open source it (probably under a new project) and go onto an AR headset version!
In particular, I know I have to switch the 70mm focal length lens with 100 - 120mm to cover the entire image! I also am going to change the lens design to have an IPD system!
With this, I will print the headset parts down to the knob adjustment system as a way to see what changes might need to happen!
WalkerDev
