First task is to design an 8 channel audio out board based on the Cirius CS42448.
don’t need any inputs.
Need to look at output scaling for Eurorack and line level.
Think initially I will make a pcb that a teensy can connect to directly, but eventually I may add the circuitry directly to the drum machine pcb.
Realising that I need to build this for Teensy 4.0 / 4.1 as other models are not available. This means less Ain pins but will have to do the multiplexing idea.
