That previous work partially presented in previous post prove to be good mod. That modified ART DJ Pre - II works stable and objectively measured much better then in original configuration. But now I have something even better, observing the position of Gain for my Pioneer Pro-DJ PC-X5 cartridge, which is no other then branded(OEM) AT-3600L i get puzzled why it needs the same ~+4 Gain trim which is like +39-40dB on printed scale, and on the other hand on my made Lab-Preamp (that metal box at my wok bench pics.) measurements shows that it can be put on +34-35dB to get same -1..-3dB signal levels. So I took of little 5k gain pot and find out source of problem is non linear etc. its logarithmic nature of strange applied amplification design.
It look like this:
Vin-mV | Vin | Vout-5k-1M-OFF | Ohm | Position | Vp-p (V) | avg(3x) | +dB |
10mV | 0,01 | "-10 Begining" | 5302 | 0 | 0,294 | 0,294 | 29,36695 |
5006 | 1 | 0,295 | 0,295 | 29,39644 | |||
4001 | 2 | 0,296 | 0,296 | 29,42583 | |||
3003 | 4 | 0,312 | 0,312 | 29,88309 | |||
1980 | 5 | 0,324 | 0,324 | 30,2109 | |||
"1/4" | 1400 | 3 | 0,336 | 0,336 | 30,52679 | ||
987 | 6 | 0,372 | 0,372 | 31,41086 | |||
Zero "0" at 50% | 681 | 7 | 0,488 | 0,488 | 33,7684 | ||
467 | 8 | 0,704 | 0,704 | 36,95145 | |||
"3/4" 25% | 84,5 | 9 | 1,73 | 1,73 | 44,76092 | ||
"+10 End" | 2,5 | 10 | 1,785 | 1,4849 | 45,03 |
In short by "fixing" inverse log position of DJ Pre II by switching to new 2,5k Lin pot. we can get almost linear selection of gain:
| 2K5 Lin potenciometar | Position in % | Omh | no | Vpp | "+dB" |
| 10mV | 0 | 2500 | 0 | 0,56 | 34,96376 |
| 25 | 1 | 0,64 | 36,1236 | |
| 33,3 | 2 | 0,69 | 36,77698 | |
| 50 | 3 | 0,88 | 38,88965 | |
| 66,7 | 4 | 1,09 | 40,74853 | |
| 75 | 5 | 1,88 | 45,48316 | |
| 100 | 6 | 4,92 | 53,8393 |
To get beyond +45dB up to that +53.8 gain, you need to disconnect Pot pin 1 and 4 or to bypass then with 100k-1M Ohm.
If you omit those resistors for Pot bypass (left open pin 1-2, 4-5) you will get no more then +53,9dB at the best.
So until my 2k Lin Burns (2 gang - stereo) Potentiometer arrives box stays open.
Best regards,
dr Jovan I.
