16x channels
16x physical steps (chainable)
4x cv out channels
Midi in and out
Per step polyphony (maybe not all channels)
Drum / voltage sequencer
16x channels
4x cv out channels
Midi in and out
I wanted to figure out the best way to run many LEDs quickly without using loads of IO pins. Here I tested using shift registers. I tried two methods, shiftOut() and SPI. I ran a test setting 16bits and recorded the time. Results:
- shiftOut() = 204 μs
- SPI = 16 μs
Clearly SPI is much faster. Below are both methods.
SPI Schematic:
SPI test code:
#include <SPI.h>
//int pll_d=11; //piedino data
//int pll_c=13; //piedino clock
int pll_l=10; //piedino latch
#define DATAOUT 11//MOSI
#define DATAIN 12//MISO
#define SPICLOCK 13//SCK
int timer = 0;
uint16_t ledNumbers[17] = { 0b0000000000000000,
0b1000000000000000,
0b0100000000000000,
0b0010000000000000,
0b0001000000000000,
0b0000100000000000,
0b0000010000000000,
0b0000001000000000,
0b0000000100000000,
0b0000000010000000,
0b0000000001000000,
0b0000000000100000,
0b0000000000010000,
0b0000000000001000,
0b0000000000000100,
0b0000000000000010,
0b0000000000000001};
void setup () {
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(pll_l, OUTPUT);
SPI.begin();
Serial.begin(9600);
SPI.setDataMode(SPI_MODE0);
SPI.setBitOrder(LSBFIRST);
SPI.setClockDivider(SPI_CLOCK_DIV2);
timer = micros();
digitalWrite(pll_l,LOW);
SPI.transfer(ledNumbers[0]);
SPI.transfer(ledNumbers[0] >> 8);
digitalWrite(pll_l,HIGH);
timer = micros() - timer;
Serial.println(timer);
void loop() {
// put your main code here, to run repeatedly:
for(int x = 0; x < 16; x++){
turnOn(ledNumbers[x + 1]);
delay(500);
void turnOn(uint16_t bitNum){
SPI.transfer(bitNum);
SPI.transfer(bitNum >> 8);
shiftOut() Schematic:
shiftOut() Code:
int DS_pin = 11;
int STCP_pin = 12;
int SHCP_pin = 8;
uint16_t ledOutput = 0;
0b1000000000000000,
0b0100000000000000,
0b0010000000000000,
0b0001000000000000,
0b0000100000000000,
0b0000010000000000,
0b0000001000000000,
0b0000000100000000,
0b0000000010000000,
0b0000000001000000,
0b0000000000100000,
0b0000000000010000,
0b0000000000001000,
0b0000000000000100,
0b0000000000000010,
void setup()
Serial.begin(115200);
pinMode(DS_pin,OUTPUT);
pinMode(STCP_pin,OUTPUT);
pinMode(SHCP_pin,OUTPUT);
turnOn(4);
delay(500);
turnOn(8);
delay(500);
turnOn(12);
delay(500);
turnOn(16);
delay(500);
turnOff(4);
delay(500);
turnOff(8);
delay(500);
turnOff(12);
delay(500);
turnOff(16);
void loop()
void turnOn(int bitNum)
ledOutput |= ledNumbers[bitNum];
digitalWrite(SHCP_pin, LOW);
shiftOut(DS_pin, STCP_pin, LSBFIRST, ledOutput);
shiftOut(DS_pin, STCP_pin, LSBFIRST, ledOutput >> 8);
digitalWrite(SHCP_pin, HIGH);
void turnOff(int bitNum)
ledOutput &= ~ledNumbers[bitNum];
