Wanted to test the speed difference between using a multiplexer to read multiple potentiometers from one analog pin vs having them on individual pins.
Code I used. Reads pot 8 times via multiplexer and prints time, then reads pot 8 times the normal way and prints time.
#define number_of_mux 1
#define numOfMuxPins number_of_mux * 8
#define channelA 2
#define channelB 3
#define channelC 4
#define comPin 14
int analogVal[8];
unsigned long timer;
void setup()
Serial.begin(9600);
pinMode(channelA, OUTPUT);
pinMode(channelB, OUTPUT);
pinMode(channelC, OUTPUT);
pinMode(comPin, INPUT);
digitalWrite(channelA, LOW);
digitalWrite(channelB, LOW);
digitalWrite(channelC, LOW);
MuxRead();
//delay(4000);
normalRead();
//delay(4000);
void loop()
void selectChannel(int chnl)
{ //// Select channel of the multiplexer
int A = bitRead(chnl,0); //Take first bit from binary value of i channel.
int B = bitRead(chnl,1); //Take second bit from binary value of i channel.
int C = bitRead(chnl,2); //Take third bit from value of i channel.
digitalWrite(channelA, A);
digitalWrite(channelB, B);
digitalWrite(channelC, C);
void MuxRead()
timer = micros();
for(int i = 0; i < numOfMuxPins; i++)
selectChannel(i);
analogVal[i] = analogRead(comPin);
timer = micros() - timer;
Serial.print("muxRead = ");
Serial.println(timer);
Serial.println("**************************************");
void normalRead()
timer = micros();
Serial.print("normalRead = ");
Results (in micros):
muxRead = 141
normalRead = 140
Multiplexer schematic:
