mantisDeck
the matching cyberdeck to control the mantis robot
The project was started to run ROS for my 6-axis Robot arm "Mantis". By the time Raspberry Pi'( 2- 3) where to slow to fully run ROS and rvis. So I searched the used PC market and found the
"Fujitsu Esprimo Q920 Mini PC". They are quite nice cheap and feature a Intel i5, standard ram and SATA SSD. So all in all a nice computer, but of course we need to do it in style.
years Ago (2016) I used an iPad screen as second display for my laptop since it is no longer in use I decided to use it there.
Since we want to be mobile I decided to build a Battery box with my own robot battery system.
For Input I used some 3 -axis joysticks and an ESP32 with BLE mounted to a Bluetooth keyboard.
Everything is placed in a ESD save "euro"-box (the nice black one) of course with custom inlay and some decals.
Currently the work itself is done. I'm working now on the documentation so be a little patient but I will publish all the 3D printed
All the files are released at:
https://github.com/4ndreas/mantisDeck
The Deck
The main deck is composed of a Fujitsu Esprimo Q920 Mini PC with a 9.7inch "IPad" LCD with a display port adapter board. A 3D printed case with stand.
PowerBank
Just a very quick intro to the "PowerBank"
For the power supply and battery I used a 24V - 6A  custom LiFePo4 pack I made for my "Omi Wheel" Rover. You can take a look at the Rover for more information about the battery pack
https://hackaday.io/project/166048-mantis-rover
I made case with a handle and mounted a 300W pure sine inverter to it. All in all a very nice Powerbank.
Keyboard
The Keyboard is a RK61 with has a build in battery and Bluetooth. I connected an ESP32 to the 3V3 power line with the awesome BLE-Gampad library. The sketch is rather simple and in the git repository.  (did I mention that everything works over Bluetooth?)
  • 1 × Fujitsu Esprimo Q920 Mini PC
  • 1 × ESP32
  • 2 × 3-axis joystick with button
  • 1 × 2048x1536 9.7inch LCD Display LP097QX1
  • 1 × RK61 Mechanical Keyboard with Bluetooth
View all 6 components
  • Fujitsu Esprimo Q920 Mini PC
    Andreas Hoelldorfer • 10/13/2022 at 12:56 • 0 comments
    Inside we finde 2 Ram slots a 2.5" STATA disc bay with screw less mounting and a PCIE (?) slot for WiFi.
    I recommend buying one with WiFi included since there are no antennas otherwise.
    The other side of the board features the CPU power supply , 1x -  M.2 slot (presumably), 1x STATA for an optical drive and a header with 5V I used to power the Display (red/black wire)
    Unfortunately no Molex connector (but you can remove the nose from the connector to make it fit (2.54mm) .
    There is also an connector labeled DC-IN maybe for direct 12V power input?
  • first release of the CAD & Code
    Andreas Hoelldorfer • 09/25/2022 at 13:14 • 0 comments
    I uploaded a first release of the CAD & Code on the github repro
    There is always a step file and a set of stl files and the Arduino Sketch for the BLE joysticks.
    More details will follow soon.
View all 2 project logs
