Well.. the epoxy cured overnight and I did a tiny bit of sanding. There are some significant surface defects from the print warping, layer lines, etc that will need to be filled and sanded. With some body work and paint it might just look good! Tomorrow I'll go on the hunt for filler putty, primer, paint, and fresh sandpaper...
Can I get updated more about this🚀
Absolutely! Long time listener of soma.fm!
I recognize that web player peeking out there...perhaps I can interest you in my terminal SomaFM player written in Python:
https://github.com/MS3FGX/SomaFM
