The Lore
This is a little bit of Shadowrun-ish fan fiction to provide a background story for this cyberdeck.
Like every decker, every cyberdeck has a story. A past.
And this cyberdeck is no different.
It was born out of old, obsolete, and damaged parts. All of them used to be parts of different computers.
Regular computers. Used for playing games, for word processing, or for education.
As time passed, these computers became obsolete, and ended up in basements or attics, if they were lucky.
Others, which weren't, ended up in landfills and junkyards.
But of those who ended up in landfills, some where lucky, in that they were picked up by scavengers.
People who collected seemingly useful things and sold them.
This was before the Great Chip Shortage of the early twenties.
And when my grandfather - may his soul rest in peace - started collecting these pieces in these years of the chip shortage, he surely wasn't aware about what would finally become of them one day.
The case
He got the case from an online Marketplace. The price was way too high for what he got.
But still, somehow it was what he wanted. He didn't care about the money, he just knew
he wanted a case that's better off being modified and worked on, instead of waiting to be
scrapped.
The case was in real bad shape, but my grandfather started filling the holes and replacing the broken pieces.
The keyboard
He got the keyboard from a friend in Vienna, a collector of weirdly modified computers. The keyboard itself wasn't modified, however. Still, it was in a place of all kinds of different and unique things, that were built by people who wanted something extraordinary.
With the keyboard in his hands, he knew that it was something unique that this keyboard would become an essential part of, too. And despite it's age, it was very well kept and taken care of. It was like brand new.
The mainboard
The component that would be home to all the electric components - the motherboard - is the odd thing in between all these old and obsolete parts.
It was made for all the old chips, but all the glue logic that connects these chips was a brand new design. Not relying on single parts that can fail, but on high-end FPGA technology.
This would be far more resilient to any external influence. On the downside, if it was broken, it was broken for good.
There was no single logic chip that you could replace, the whole mainboard would be gone and need to be replaced.
But one other advantage - and maybe the biggest one - was, that this allowed for much simpler power supply.
12V DC only, instead of 9V AC and 5V DC. This would make everything else much easier.
The other mainboard
My grandfather had another "new" mainboard at hand as well. This one was a true all-in-one solution in that it needed no additional chips. And it was able to mimic peripherals as well.
Still, it was made to fit the original case, so from the outside you wouldn't necessarily recognize what was inside.
I'm not yet sure which board to use. But if one doesn't work, I'll just try the other. And maybe both will work. If so, I'm convinced that each one will give the cyberdeck it's own unique personality.
The chips
Processor, Video chip, Sound chip, and interface chips. All these came from dealers around the place. Hand picked, for sure, but still parts that
have been taken out of their original homes. Very often, ruthless corporate suits would cannibalize otherwise good devices just for the parts.
It was obsolete hardware anyways, so why should anyone care if a fully working computer was sitting in a basement, or if the parts were sold for good money?
I can't tell you all the stories behind these components, as I haven't been there when they happened. Heck, I wasn't even born back then.
However, I'll take the parts that my grandfather has collected so painstakingly, and I'll see if I can make something good, something new out of them.
What good is a 1 MHz cyberdeck, you ask?
Rumor has it, that with The Awakening in 2011, not only humans have begun to transform. In very rare cases, old, complex things with a long life and many stories behind them might also gain something like consciousness.
All of these parts have their own story, so I hope that once they are unified, they will awake.
And this cyberdeck will be able to run the Matrix without a decker controlling it.
It might not be of much use in the real world, but it will have it's own life in cyberspace.
So, whatever the stories of all of these components were, this will be the next, common chapter for all of them.
I Hope you enjoyed it
Multiple uses for the Cyberdeck
The cyberdeck can be used for many purposes. For more depth and insights, be sure to read through the build instructions. I provide most of the technical details there.
Mssiah Midi Interface
There's multiple Midi interfaces for the C64. The Mssiah not only provides a physical Midi connector for the module expansion port, the cartridge also comes with a number of Midi applications.
Most notably, it comes with a Sequencer and a Synthesizer (among other tools)
And of course, you can also connect Midi devices to your C64 through the Mssiah module
With all components and cables required, the cyberdeck adds a lot of convenience, as you save yourself the hassle of setting up a display, including cables and power management.
The WiC64 WiFi Interface
Deck into CSDB (the C64 scene database), have your highscores recorded on a central server automatically, or join an online chat with fellow C64 deckers.
The Display
Besides extending the C64 itself, integration between the C64 and the display was designed in a way that you can always use the display with other devices. All the connectors are available externally, so you can use a FireTV stick to watch a series anytime, or feel free to connect other game systems to the display.
Composite and power connectors can be found on bottom of the display enclosure.
And of course... gaming
Besides all the serious decking and working you can do with the cyberdeck, you can still fire up your favorite game and just have a good time with the latest and greatest games like Sonic, or some good old Petscii-style adventure games.
How portable is it?
With the right equipment, it is as portable as it can possibly be.
What's still missing?
Battery
For true portability, a built-in battery is required. There is sufficient room left to add it, I just didn't find the time yet.
Power consumption of the cyberdeck is below 10 W, so about 6000 mAh should allow for about 3-4 hours of permanent use.
Built-in amplified audio
Right now, no amplifier is built into the case. While I added a speaker, it is unamplified audio only, barely audible.
For more information, read the build instructions, they provide good insights into the internals of the cyberdeck.
