[05:00]
For a smaller design and lower unique part count, I've decided to use a convex and concave lens system to collimate the light from the display. For some reason, I thought the 55mm square fresnel lens I found on AliExpress had a focal length of 35mm, but it's twice that at 70mm. I also found a 21mm concave lens with a focal length of 17.835mm. The result:
I found a 100x100mm fresnel lens with a focal length of only 35mm, so it's possible to obtain a smaller focal length. I'm going to assume I can get a 60x60mm fresnel lens with a 30mm focal length.
Next iteration:
The target was 7mm, but a sub 9mm image should suffice too, requiring a beamsplitter of >=18mm.
[some searching later...]
Oh wow:
There's also concave lenses here, and the listing says that the one below has a edge thickness of 5.2mm. The 21mm lens I found earlier only lists the centre thickness, so it's very likely that the above light path wouldn't work when the edge thickness is taken into account.
[About 1 hour later]
The dual 18mm diameter lenses reduce the 52mm square image down to 3.1mm. Merging 3.1mm beams is also going to be... interesting. After all the mergers, the beam size is doubled to 6.2mm. It then goes through a 3rd 18mm lens and then a larger lens before hitting another 30mm focal length fresnel lens. For the D43mm lens, an image of infinite distance is almost identical in size to the input. For the D40.5mm lens, an image of 5.97m distance is 13% larger.
It looks like it's about £5 per lens, so that's 5 * (4 * 3 + 2 * 3) = 5 * 6 * 3 = £90 in optics. Not great, but looking how much some singular sets of glasses cost, not terrible. If I use the 120Hz display driver board on AliExpress, the combined cost would lie somewhere around £400, depending on if there's a sale or not. This makes me think that the full BOM could be £599.
[5:20] There's a cheaper solution than using the D43 lens:
Image size: 52.75mm
[13:45] Turns out a fresnel lens focal point of 30mm was a good starting value, as 28 or 32 gives me an image way too large or small. Looking at IPD charts on the internet, I think targetting a 55mm IPD instead of 60 would be more inclusive. I'll see if I can get something like a 55x60mm or 55x65mm F30 fresnel lens so that I can hold the lens on the 2 shorter faces.
