[09:05] Considering that most VR and AR systems today... actually basically every one I know of (even the Meta prototypes) have PPDs well under 80, I'm thinking that I should be more cautious with my optical path. This was brought to my attention when I found out about this AR lens module:
It's also notable that it's up to 25% transparent in this industry. Perhaps that means that I could use a R60:T40 beamsplitter instead of a 50% splitter.
Anyway, I'm still unconvinced that the fresnel lens is going to give me the optical quality I desire, so I went on AliExpress.
Then I found a bunch of achromatic lenses that all had rather high focal lengths for this application. I also found a parabolic mirror, but the simulation didn't reflect light like I hoped it would (90 degree reflection + focusing).
[15:50] It's interesting that AliTools only has historical data for both lenses that only go back 1 week. Is the reason why I never found them before related to the part where they never existed until very recently? I also noticed that the lens is F45mm not F47mm as I thought in the simulation. I doubt it'll change much. (Can confirm. I was able to move the screen forward 4mm though.)
[Feb 2 at 02:33] Me: Wrapping things up and about to buy
Aw the exchange rate went up? Wait. F100mm?
checks bottom of basket
clenched teeth facepalm
Second time I've had a solution and then got hit with Out Of Stock. I'm guessing in this case it was a listing error.
A solution... will have to be recalculated.
I mean... this lens I found from the same seller still exists. It was in my basket and I was about to remove it.
A solution... still has to be recalculated.
