Now, the simulation isn't completely accurate. I can't change the grid size so I've multiplied all measurements by 10 and the lens is only 26 scaled mm instead of 27, but the difference is quite drastic between the formula and raytracing.
At least I'm correct in thinking that if there is a F-4mm lens 26mm away from a F30 lens (in other words, 4mm away from the F30's focal point, the light will be parallel:
So what if I trace it backwards from the double concave lenses?
Well that failed. Oh right, the distance between lenses moved. Ok, what if I calculate a few permutations?
And the equation for thick lenses isn't even that different:
