So that the helmet is easier on the eyes, I've swapped out sharp corners for smooth fillets. I'm also trying different textures again.
I think it actually looks quite relaxing and comfortable with this walnut skin, thus the aesthetic geometry of the helmet is good enough for me. (If the helmet didn't look good no matter what texture I slapped on, I'd have to go back to the drawing board.) This helmet does make me think of a hood dryer, which is probably a decent initial thought for someone to have.
Oh right. Whilst I'm writing this log I should mention this helmet I found:
Due to space constraints, I'm thinking that the air pathway of TyMist is going to be similar to this. It's already got a similar front visor. The VOC filter input is expected to be around about here:
I've also imported the headphone cup concept and the speakers I'm planning on using might be a tight fit:
