Initial stuff
A project log for hgDeck
wearable (not) voice-controlled cyberdeck
igor-brkicIgor Brkic • 09/28/2022 at 10:42•0 Comments
After some thinking about what would be fun to build (and also giving myself a limit that it can only contain stuff that I already have and shouldn't take longer than a few days to build) I decided on a convertible form factor but with an automatic open/close mechanism. To initiate mode change I also decided to go with voice commands. And since the keyboard I had is a bit wider than the display, I decided to add another small display.
The idea is to have it mounted on a wrist and it can show and capture image in front of it but also it can switch to terminal mode where the keyboard can be used.
The keyboard I had is the one I purchased some time ago and it's a really nice one - keys are quite acceptable and it can pair and switch between two devices. Unfortunately I can't find it any more (the original purchase link is https://www.aliexpress.com/item/4000041976542.html)
For the mode changing mechanism I decided to design some sort of linkage capable of switching the modes and use a small servo to drive it.
So, after some initial 3D modeling and deciding on placement I ended up with this:
