11Late redesign of motor paddle attachment
Belated improvements to motor paddle attachment to UJ are shown in the next two pictures. The redesign uses three furniture brackets to avoid unwisely driving load-bearing wood screws into plywood end grain. Note the dual-use hole in the lower corner at red stain and spacer washers at top and center.
I lubricate the heliostat with PTFE spray, a dry bicycle lubricant.
David Matthew Mooney
