Made a quick thru-hole prototype, totally forgot the capacitor in series with the microswitch
and had to add it directly to the switch terminal.
A project log for Spot Welder & Bag Sealer Timer Board
This is a simple Timer and SSR board to implement in the well known DIY MOT spot welder, and also is meant to replace a bag sealer board.
