Project is still in progress.
I had a hard time trying to figure out how to put all this stuff onto a 90x50mm stripboard, and finally decided to stack 2 stripboards of that size:
- LED matrix, buttons and pots above
- all IC, caps, resistors underneath
with pin headers to connect both stripboard (a bit like Arduino shields).
Board design is not complete yet but I'm almost there, hope to finish it tomorrow and implement it this week-end. Design is available on github (as LochMaster files).
Besides, I have ported the current prototype (with only buttons) from Arduino UNO to ATtiny84 and it works fine.
However, I noticed some issues with the light level of LEDs in the matrix; reducing resistors values helped a little bit but not that much; I need to find a way to provide enough current for a complete row of LEDs but I'd like to avoid adding transistors to the circuit...
Finally, on FastArduino library, I could finally implement Analog Digital Conversion, hence I'll soon be able to replace buttons to move cursor backward/forward with 2 pots (one for X, one for Y), which will make it faster and easier for the user to select LEDs to set for the first generation of the game.
Hopefully this week-end, the prototype will be running fine with 2 pots.
Jean-François Poilpret
