The boards are finished (see project newly updated picture), the program currently runs fine and is less than 1KB.
I still need to:
- Add some matrix cleanup at the end of the game
- Possibly add possibility to change game speed through one of the pots
- Add an electronics schema of the global circuit
- Finish the README on github
In addition, I consider one improvement to the code, by making it parametered on matrix size (not fixed to 8x8) and check if program size would still fit under 1KB for e.g. 16x16.
Jean-François Poilpret
