Raspberry Pi Phone
Raspberry Pi Phone-Your Own Phone That Can Call and Text Under $70
Public Chat
A year ago I noticed a project to build a Raspberry Pi phone. It was $200, and what I realized was that the code would not work because it was made 8 years ago and the software was outdated. That phone could Call, text, and take photos. I changed the code so it works without a SIM card and this phone can call, text, play games, and more.
FL0NXN4I9SMNELN (3).3mf
3mf - 98.00 kB - 10/04/2022 at 21:11
Download
FEJ437XI9SMNELS (1)_220520_034725.3mf
3mf - 43.77 kB - 10/04/2022 at 21:11
Download
  • 1 × Raspberry Pi 3 b+
  • 1 × Micro Sd card
  • 1 × Inland 3.5 inch TFT touchscreen with stylus
  • 1 × USB Microphone
  • 1 × USB Wifi adapter Connectors and Accessories / Telecom and Datacom (Modular) Connectors
View all 6 components
  • Attaching Parts
    PiCreate10/04/2022 at 21:14 0 comments
    Connect the pins on the raspberry pi to the screen. To test the connection, plug in the raspberry pi. The screen should glow white. Take the SD card, and install it with the latest version of Rasbian. Attach the USB microphone and adapter.
View project log
  • 1
    Attaching Parts
  • 2
    Coding
    Attach raspberry pi to monitor, and go through the setup guide. Go into a terminal and type
    sudo rm -rf LCD-show
    git clone https://github.com/goodtft/LCD-show.git
    chmod -R 755 LCD-show
    cd LCD-show/
    sudo ./LCD-show 90
    Wait a few minutes until your monitor turns off and your screen turns on. Open another terminal and type
    sudo nano /usr/bin/toggle-keyboard.sh
    than inside the file type
    #!/bin/bash
    PID="$(pidof matchbox-keyboard)"
    if [  "$PID" != ""  ]; then  kill $PID
    else matchbox-keyboard &
    fi
    Press ctrl+x, then y, then enter to save.
    Type
    sudo chmod +x /usr/bin/toggle-keyboard.sh
    Once that is done type
    sudo nano /usr/share/raspi-ui-overrides/applications/toggle-keyboard.desktop.
    Inside the file type
    [Desktop Entry]
    Name=Toggle Virtual Keyboard
    Comment=Toggle Virtual Keyboard
    Exec=/usr/bin/toggle-keyboard.sh
    Type=Application
    Categories=Panel;Utility;MB
    X-MB-INPUT-MECHANISM=True
    Then press ctrl+x, then y, then enter to save.
    Run cp /etc/xdg/lxpanel/LXDE-pi/panels/panel /home/pi/.config/lxpanel/LXDE-pi/panels/panel than
    nano /home/pi/.config/lxpanel/LXDE-pi/panels/panel. Go to the bottom and type
    Plugin {
     type=launchbar
     Config {
      Button {
       id=toggle-keyboard.desktop
    sudo reboot. When the screen loads again, on the taskbar you should see a keyboard. This is for texting.
  • 3
    Calling and Texting
    On your computer type www.poptox.com. This is a google website that is a dialer. Subscribe for any plan you want, from $10 to $50. You will get unlimited calls. Type this in the raspberry pi browser and star it so you don't have to type to get it. Go to Vonage to get a free trail texting. Star that too. Anything you want to add like games, star. If you want to text, open google, click the Vonage star, and click the keyboard in the taskbar.
View all 5 instructions
Rich text editor
PiCreate wrote 11/11/2022 at 12:32 point
For audio you can get raspiaudio mic ultra++
