ARDUINO-BLUETOOTH-CONTROLLED-SMART-IRRIGATION-SYS
HERE in this article I am going to show how to make a smart irrigation system at home. This is very easy to make & of course its a prototype
HERE in this article I am going to show how to make a smart irrigation system at home. This is very easy to make and ofcourse its a prototype project which could be modified according to our need. I have made this basically for the begineers or the intermediates. This is an ARDUINO BASED project which makes it user friendly and if you are looking for a project to show some where like science exhibitation, final year college project presentation, environmental science project, agricultural project etc in several field then this is really a good project that you may try. Mkaing cost for this project is also very low.
WHY AUTOMATIC IRRIGATION SYSTEM IS NEEDED
The benefits of automatic irrigation are:
  • reduced labor.
  • timely irrigation — plants being watered when needed.
  • management of higher flow rates.
  • accurate cut-off of water compared to manual checking.
  • reduced runoff of water and nutrients.
  • reduced costs for vehicles used to check irrigation.
PARTS OF THE PROJECT
To make and understand it easily we have splatted this project into two main parts.
  • MECHANICAL Part
  • ELECTRONICS Part
for better explanation we have divided our ELECTRONICS Part into
  • Circuit and PCB
  • Assemble the electronics components
  • ARDUINO coding
JPEG Image - 561.82 kB - 10/06/2022 at 14:58
Preview
arduino code.txt
plain - 3.40 kB - 10/06/2022 at 14:57
Download
  • 1 × arduino nano
  • 1 × l293d motor driver
  • 1 × hc-05 bluetooth module
  • 4 × tt gear motor 60rpm
  • 4 × wheels
View all 9 components
  • 1
    MECHANICAL PART
    Here in this part we will need some PVC sheet to make the chassis, 4 TT gear motors with wheels, 1 submersible pump, one coldrinks can which is completely optionnal. you may use anything elese to make the water tank. This is considered as the easiest part of this robot. All you need to only cut the PVC sheet and assemble all the components together in a proper way. Here i have attahed some pictures on this.
    Here i have used 60rpm TTgear motors but you may vary the rpm according to your need. But one tips i want to share that, lower rpm motos are easy to control & they could be shown easily in any resentation. Thats it for this part. now we will move to our next part which is ELECTRONICS PART. Here we will directly enter into the circuit and pcb making part. This could be littlebit tough if you are a fresher in making electronice project but i will explaint is as much easier as possible.
  • 2
    CIRCUIT & PCB MAKING
    Here I have attached the circuit or the connection diagram which is very easy to understand and make. Please follow this diagram when you are going to make this project.
    This project will work or perform same with or without making pcb but I have made PCb boards for this project. Actualy not only for this, I always do prefer making any project using Customized PCB boards. There have obviously some advantages of making any project using PCB boards. like
    • Compact Size and Saving of Wire.
    • Ease of Repair and Diagnostic. If in case of any damage, it's very easy to check and replace the particular failure components.
    • Saving of Time.
    • Immune to Movement.
    • Tight connections and Short Circuits Avoided.
    • Low Electronic Noise.
    • Low Cost.
    • Reliability.
    So i always make PCB BOARD for my every project. As I have already mentioned before I have already attached a circuit diagram with this article so please download that before you are going to connect all of them together. In my case, I have made a customized PCB board from JLCPCB to skip a few steps of wiring and make an easy connection between all the components.$2 for 5pcs PCBs, PCBA from $0, Register to Get Free Coupons here: https://jlcpcb.com/IYB. I really liked the PCB Boards as they are very high in quality.
  • 3
    ASSEMBLE THE ELECTRONIC COMPONENTS
    Now we will make all the components together. But before that please make sure that you have gathered all of them correctly. Here i have enlisted the components and also provided their pictures for your references. Hope this will help you to make this easier.
    SO THE COMPONENTS THOSE WILL BE NEEDED ARE
    • ARDUINO NANO WITH CABLE
    • L298N MOTOR DRIVER
    • HC-05 BLUETOOTH MODULE
    • M4 DIODE
    • RED LED
    • 78M05 VOLTAGE REGULATOR
    • 220uF CAPACITOR
    • TERMINAL BLOCKS
    • HEADER PINS
    Now please assemble all the components together to complete the project. this is very easy to do if you follow the simple connection diagram. But if you have any doubt on this you may watch this video for better understand
    after assemble all the electronics part together only one thing will be left for us which is ARDUINO CODING. Trust me this part is really very easy as compared to these previous parts. So lets finish it...
View all 5 instructions
