I used a combination of 3d printed parts (White parts), CNC cut acrylic, with a 4mm thick aluminum composite board as the back panel to give the map rigidity.
A project log for The Interactive Air Quality Map
A Physical Touch Reactive Map that shows the Air Quality of a location
