For designing your building or structure, any digital design tool should work now. I use Revit to design the larger structures and Fusion360 to design smaller components. Then I export as PDF and send to Automatic Construction for fabrication.
A project log for Automatic Construction: Inflatable Building
Automatic Construction inflates concrete buildings that sequester CO2. Cheap but durable buildings that save the world
