Notes:
LSP:
- LSP is new (orignated in early 2016 by Microsoft)
- List of LSP Servers and assessment of how well they are maintained:
- Spec: https://microsoft.github.io/language-server-protocol/
- LSP is a JSON-RPC protocol
PowerShell Editor Services:
- The only listed LSP server for PowerShell is the one maintained by Microsoft
- Powers the PowerShell Extension for VSCode
- You can connect to it using Named Pipes or Stdio
- Documentation:
- Index:
- User Guide:
- API Reference (.NET API??):
- https://github.com/PowerShell/PowerShellEditorServices/blob/main/docs/api/index.md
- NuGet package:
- I believe this just controls the services aspect. Maybe I can start it and manage it in .NET?
- FuGet.org page:
- "The Host Process" - what is this? Got it! This is the doc on how to use STDIO
- https://github.com/PowerShell/PowerShellEditorServices/blob/main/docs/guide/using_the_host_process.md
- states that the only way to interact is with stdio despite the README which says that named pipes are supported??
- goes over LSP in detail
- PowerShell Extension Terminal uses this method
- Named Pipes API (which there is no document for this, guess I gotta learn how to use named pipes lmao)
- Visual Studio Code, Vim, and IntelliJ use this method - Vim uses this?? Isn't Vim old????
