Alright, now to test support for it:
- Can I get an executable? yes:
- Download PSES (PowerShellEditorServices.zip):
- Run the following script to start the server:
- Can I access stdio? -not powershell readline...
- Can I access the named pipe?
- Is there a consistent name for the pipe? no it is randomly generated
- If not, can I write a script that detects it? yes, however it is uses c++ naming convention.
- Can I write a PowerShell function that gets one under the c# convention? yes, just need to run "($name -split "\\") | select -last 1"
- Can I write a powershell script that connects then disconnects from it?
- Can I send anything to the server via powershell?
- If yes, can I send the contents of a JSON file via an LSP request to the server?
- Can I get a unit testing script running? yes, I'm writing one
- Posted yet?
If this works, I need to make a comprehensive list of every Request and Notification that I need to be able to send to the server.
Parsing responses will come with time, as I can just dump unknown responses to a text file and read them later.
Nicholas Jackson
Brief hold on log while running errands :)
