PROBLEM: VAGUE COMMAND LINE ARGUMENTS.
Start-EditorServices.ps1 has vague command line arguments
RESEARCH: Start-EditorServices.ps1
[CmdletBinding(DefaultParameterSetName="NamedPipe")]
param(
[Parameter(Mandatory=$true)]
[ValidateNotNullOrEmpty()]
[string]
$HostName,
[string]
$HostProfileId,
[string]
$HostVersion,
[string]
$BundledModulesPath,
$LogPath,
[ValidateSet("Diagnostic", "Verbose", "Normal", "Warning", "Error")]
$LogLevel,
[string]
$SessionDetailsPath,
[switch]
$EnableConsoleRepl,
[switch]
$UseLegacyReadLine,
[switch]
$DebugServiceOnly,
[switch]
$LanguageServiceOnly,
[string[]]
$AdditionalModules,
[string[]]
$FeatureFlags,
[switch]
$WaitForDebugger,
[switch]
$ConfirmInstall,
[Parameter(ParameterSetName="Stdio", Mandatory=$true)]
[switch]
$Stdio,
[Parameter(ParameterSetName="NamedPipe")]
[string]
$LanguageServicePipeName = $null,
[string]
$DebugServicePipeName = $null,
[Parameter(ParameterSetName="NamedPipeSimplex")]
[switch]
$SplitInOutPipes,
[string]
$LanguageServiceInPipeName,
[string]
$LanguageServiceOutPipeName,
[string]
$DebugServiceInPipeName = $null,
[string]
$DebugServiceOutPipeName = $null
Import-Module -Name "$PSScriptRoot/PowerShellEditorServices.psd1"
Start-EditorServices @PSBoundParameters
This script is just a wrapper for the Start-EditorServices function in PowerShellEditorServices.psd1
RESEARCH: PowerShellEditorServices.psd1
This psd1 (hashtable as a manifest) with the following relevant keys:
# Script module or binary module file associated with this manifest.
RootModule = if ($PSEdition -eq 'Core')
'bin/Core/Microsoft.PowerShell.EditorServices.Hosting.dll'
else
'bin/Desktop/Microsoft.PowerShell.EditorServices.Hosting.dll'
# Cmdlets to export from this module, for best performance, do not use wildcards and do not delete the entry, use an empty array if there are no cmdlets to export.
CmdletsToExport = @('Start-EditorServices')
I'm running core on my instance, so we will checkout cre
RESEARCH: core/Microsoft.PowerShell.EditorServices.Hosting.dll
I need to figure out how this module was built.
RESEARCH: PSES/PowerShellEditorServices.build.ps1
Code that publishes the output of the build:
# PSES/bin/Core
foreach ($hostComponent in Get-ChildItem $script:HostCoreOutput) {
if (-not $includedDlls.Contains($hostComponent.Name)) {
Copy-Item -Path $hostComponent.FullName -Destination $psesCoreHostPath -Force
The directory with build output is stored at $script:HostCoreOutput
RESEARCH: $script:HostCoreOutput
$script:HostCoreOutput = "$PSScriptRoot/src/PowerShellEditorServices.Hosting/bin/$Configuration/$($script:NetRuntime.PS7)/publish"
It is only used once. Maybe we can find more from $Configuration and NetRuntime.PS7?
This doesn't seem to turn up much
Maybe we can get some data from buildinfo?
RESEARCH:CreateBuildInfo
There are 2 variations of CreateBuildInfo:
Task Build FindDotNet, CreateBuildInfo, {
# NOTE: We use /p:UseSharedCompilation=false to work around a bug with CodeQL.
Exec { & dotnet restore $VerbosityArgs }
Exec { & dotnet publish /p:UseSharedCompilation=false $VerbosityArgs -c $Configuration .\src\PowerShellEditorServices\PowerShellEditorServices.csproj -f $script:NetRuntime.Standard }
Exec { & dotnet publish /p:UseSharedCompilation=false $VerbosityArgs -c $Configuration .\src\PowerShellEditorServices.Hosting\PowerShellEditorServices.Hosting.csproj -f $script:NetRuntime.PS7 }
if (-not $script:IsNix) {
Exec { & dotnet publish /p:UseSharedCompilation=false $VerbosityArgs -c $Configuration .\src\PowerShellEditorServices.Hosting\PowerShellEditorServices.Hosting.csproj -f $script:NetRuntime.Desktop }
# Build PowerShellEditorServices.VSCode module
Exec { & dotnet publish /p:UseSharedCompilation=false $VerbosityArgs -c $Configuration .\src\PowerShellEditorServices.VSCode\PowerShellEditorServices.VSCode.csproj -f $script:NetRuntime.Standard }
This reveals that there is build information in these files:
- \src\PowerShellEditorServices\PowerShellEditorServices.csproj
- \src\PowerShellEditorServices.Hosting\PowerShellEditorServices.Hosting.csproj
It calls the last one twice, once for core, and once for windows
Task CreateBuildInfo {
$buildVersion = "<development-build>"
$buildOrigin = "Development"
$buildCommit = git rev-parse HEAD
# Set build info fields on build platforms
if ($env:TF_BUILD) {
if ($env:BUILD_BUILDNUMBER -like "PR-*") {
$buildOrigin = "PR"
} elseif ($env:BUILD_DEFINITIONNAME -like "*-CI") {
$buildOrigin = "CI"
} else {
$buildOrigin = "Release"
$propsXml = [xml](Get-Content -Raw -LiteralPath "$PSScriptRoot/PowerShellEditorServices.Common.props")
$propsBody = $propsXml.Project.PropertyGroup
$buildVersion = $propsBody.VersionPrefix
if ($propsBody.VersionSuffix) {
$buildVersion += '-' + $propsBody.VersionSuffix
# Allow override of build info fields (except date)
if ($env:PSES_BUILD_VERSION) {
$buildVersion = $env:PSES_BUILD_VERSION
if ($env:PSES_BUILD_ORIGIN) {
$buildOrigin = $env:PSES_BUILD_ORIGIN
[string]$buildTime = [datetime]::Today.ToString("s", [System.Globalization.CultureInfo]::InvariantCulture)
$buildInfoContents = @"
// Copyright (c) Microsoft Corporation.
// Licensed under the MIT License.
using System.Globalization;
namespace Microsoft.PowerShell.EditorServices.Hosting
public static class BuildInfo
public static readonly string BuildVersion = "$buildVersion";
public static readonly string BuildOrigin = "$buildOrigin";
public static readonly string BuildCommit = "$buildCommit";
public static readonly System.DateTime? BuildTime = System.DateTime.Parse("$buildTime", CultureInfo.InvariantCulture.DateTimeFormat);
if (Compare-Object $buildInfoContents.Split([Environment]::NewLine) (Get-Content $script:BuildInfoPath)) {
Write-Host "Updating build info."
Set-Content -LiteralPath $script:BuildInfoPath -Value $buildInfoContents -Force
This reveals that there is data within .\PowerShellEditorServices.Common.props
This also suggests that whatever is in $script:BuildInfoPath contains more build info
RESEARCH: $script:BuildInfoPath
It is resolved on this line:
$script:BuildInfoPath = [System.IO.Path]::Combine($PSScriptRoot, "src", "PowerShellEditorServices.Hosting", "BuildInfo.cs")
Which should resolve to .\src\PowerShellEditorServices.Hosting\BuildInfo.cs
RESEARCH: BuildInfo.cs
This appears to just be a cs file that packs the build number into the published app
RESEARCH: PowerShellEditorServices.Common.props
This appears to just be some kind of .NET manifest
RESEARCH: PowerShellEditorServices.csproj + PowerShellEditorServices.Hosting.csproj
Neither of these 2 provide anything super revealing. So maybe the builder just compiles everything in their parent directories?
Nicholas Jackson
