These logs are not in order as I am kinda starting from the end and moving backwards.
I am shipping my first unit out to NY this week. It supports (insecure) OTA firmware and code updates, so it shouldn't require a serial connection to consume updates.
It isn't pretty and the code is a bit slapped together but it works and is robust enough to send out
