The speakers are not going to fit without removing the battery compartment, so I simply had to remove it (It's a feature I haven't used anyway).
![](https://cdn.hackaday.io/images/3415041665764082984.jpg)
Since the battery hatch will not be used from now I added some glue to keep it closed. I drilled holes for the speaker cones to improve the treble, and added some metal mesh for protection.
![](https://cdn.hackaday.io/images/4680911665764330147.jpg)
![](https://cdn.hackaday.io/images/5532741665764651919.jpg)
![](https://cdn.hackaday.io/images/2064041665764799813.jpg)
![](https://cdn.hackaday.io/images/7369791665765204479.jpg)
