I wanna be able to turn off the power to the amplifier, so I drilled a hole in the case and added a switch
![](https://cdn.hackaday.io/images/49131665765524469.jpg)
![](https://cdn.hackaday.io/images/461531665765558586.jpg)
I also want a power indicator so I don't forget to turn off the power to the amplifier, so I added an LED next to the volume knob.
![](https://cdn.hackaday.io/images/7579191665765635564.jpg)
![](https://cdn.hackaday.io/images/3463691665765668794.jpg)
A project log for Microkorg speaker mod
The microkorg is a wonderful machine. One of the cons is the lack of internal speakers, but that can be changed!
