The Microkorg case is now modded, and it's time to attach the amplifier and speakers. I glued them both to the bottom of the case. I'm using PL600 adhesive so hopefully they won't start moving around.
I also added a relay with RC delay to increase the time before the speakers are connected to the amplifier (in case I get Turn-on and Turn-on pops), but after some initial testing I came to the conclusion that the relay wasn't needed.
Finally I can close the lid and start enjoying my Microkorg with internal speakers!
