I continued searching for a better amplifier solution and found the PAM8610 module, which has higher power rating than the PAM8403. I ran some tests with the speakers from the Sharp TV and was happy with the result. It's probably not the best Class D amplifier module but I think it's good enough.
![](https://cdn.hackaday.io/images/8333521665678618476.jpg)
